Aweray Aweseed remote networking to achieve real-time data transmission and solve the problem of remote networking in water conservancy projects
123
The construction of intelligent water conservancy system and the realization of remote monitoring and intelligent management of water conservancy facilities have become an inevitable trend in the development of the industry. However, in the process of meeting the requirements of data transmission and interconnection of water conservancy monitoring system, there are still many challenges.
● Network access problem: a large number of water conservancy monitoring stations are located in remote areas, wired networks are difficult to access, network cable laying costs are high, and construction is difficult; although there are 4G/5G wireless networks in some areas, the signal is weak and fluctuates greatly, which is difficult to meet the requirements of real-time data transmission.
● High networking cost: Traditional networking relies on public network IP or dedicated line. The application process for public network IP is complicated and the dedicated line is expensive. Especially for large-scale water conservancy projects with many sites, the networking cost is unbearable.
● Complex operation and maintenance management: water conservancy facilities are scattered, equipment types are diverse, and on-site operation and maintenance are time-consuming and laborious; Under the traditional network architecture, troubleshooting and positioning are difficult, and effective remote operation and maintenance methods are lacking, which affects the normal operation of the system.
● Data security risks: water conservancy data involves important information such as water resources allocation and flood control security, and is vulnerable to network attacks and high risk of data leakage during transmission; traditional networking security protection mechanisms are weak, making it difficult to ensure data security.
Picture alt
In view of the network problems in the monitoring and management of water conservancy facilities, Aweray Aweseed remote networking provides a set of efficient, flexible, safe and low-cost solutions. Through the SD-WAN-based remote networking technology, the convenient deployment, stable interconnection and efficient operation and maintenance of the remote monitoring system of water conservancy facilities are realized, which injects strong power into the construction of intelligent water conservancy.
Picture alt
Convenient and efficient deployment, Aweray Aweseed solve the remote water monitoring site network access problems.
Aweray Aweseed provide a series of off-site networking routers. For example, R300 series industrial routers, which have won the first market share of online e-commerce platforms in 2024 in China, support 4G/5G multiple network access methods and adapt to various complex network environments of water conservancy monitoring stations. In remote water conservancy sites that do not have wired networks, 4G/5G networks are used to quickly access the network; for areas with existing wired networks but unstable, dual-network backup mode can be adopted to ensure that the network is always online and to ensure uninterrupted data transmission.
Picture alt
Aweray Aweseed provide affordable networking solutions, and large-scale water conservancy projects can also achieve cost-effective networking.
Aweray Aweseed SD-WAN-based remote networking technology. Compared with traditional public network IP and dedicated line networking, Aweseed remote networking can make full use of existing network resources without high leased line rental costs and significantly reduce networking costs. It is especially suitable for water conservancy projects with numerous sites and extensive distribution, saving a lot of capital investment for water conservancy departments.
Picture alt
Aweray Aweseed provides powerful remote management capabilities to reduce water facilities on-site equipment deployment and operation and maintenance costs.
Aweray Aweseed support cloud deployment, operation and maintenance, plug and play. Only need to connect the Aweray Aweseed router to the network, simple configuration on the cloud platform, and support batch distribution configuration, can quickly complete off-site networking, greatly shorten the project deployment cycle, reduce the implementation difficulty, even non-professional network personnel can easily operate. At the same time, the Aweray Aweseed supports remote centralized operation and maintenance, and pushes alarm information such as equipment online status, terminal online and offline changes, network failures and the like in real time through multi-platforms such as Aweray Aweseed management App, enterprise WeChat, DingTalk, and flying books. Technics can remotely perform configuration adjustment, firmware upgrade, troubleshooting and other operations on the router without having to visit the site, greatly improving operation and maintenance efficiency and reducing labor costs and time costs.
Aweray Aweseed in data security in one step to meet the water industry security compliance requirements.
Aweray Aweseed has a complete security system from user authentication, fine management of permissions to data encryption and transmission. In addition to data transmission encryption to prevent leakage, user access rights can also be strictly controlled to ensure that only authorized personnel can access relevant data and equipment, to ensure the safe and stable operation of water conservancy facilities monitoring system. In addition, the Aweray Aweseed supports privatization deployment, which can meet the higher requirements of the water industry for data security.
At present, Aweray Aweseed provides a wide range of integrated hardware and software solutions for water conservancy facilities in different application scenarios. Whether it is reservoirs and river gates in remote mountainous areas, or pumping stations and water quality monitoring points in cities, Aweseed can be flexibly deployed to meet the core needs of remote video surveillance, data acquisition, and automation control.
Picture alt
    • Aweray Aweseed realizes real-time return of hydrological monitoring data: Aweray Aweseed industrial R300 series routers are deployed at hydrological monitoring stations such as rivers, lakes and reservoirs, sensors such as water level gauges, rain gauges and current meters are connected to the routers, and the hydrological data center can bypass and deploy Aweray Aweseed rack gateway G300/V2000 or software clients through 4G/5G or wired network access of R300 series. Subsequently, the hydrological data collected by the sensors in real time can be quickly transmitted to the hydrological data center by Aweray Aweseed remote networking. In addition, managers can also install Aweray Aweseed software clients in office notebooks and mobile phones to grasp water level changes, rainfall, water flow speed and other information in real time at any time, providing accurate data support for flood control and drought relief decisions.
    • Aweray Aweseed to realize reservoir dam safety monitoring: For monitoring equipment such as displacement sensors, osmotic pressure gauges, stress and strain gauges installed in reservoir dams, monitoring cameras are deployed at key positions such as dam crest and dam abutment, and Aweray Aweseed R300 series routers can also be connected. After the remote networking, all data and video can be transmitted to the reservoir management center, and the management personnel can remotely monitor the safety status of the dam in real time, find cracks, leakage and other potential safety hazards in time, and ensure the safe operation of the dam.
    • Aweray Aweseed to realize intelligent irrigation management in irrigation area: In the face of key positions such as water intakes, water distribution gates and pumping stations in irrigation area, Aweseed routers are deployed to transmit data of flow sensors, water level sensors, electric valve controllers and other equipment to irrigation area management platform. After the Aweray Aweseed is networked in different places, the irrigation area management platform can receive equipment data remotely, and the management personnel can also remotely control the irrigation water volume and switch valves in real time according to the water demand of crops, so as to realize intelligent and accurate irrigation, improve the utilization efficiency of water resources, and promote agricultural water saving and efficiency.
    • Aweray Aweseed to realize monitoring of urban water supply and drainage pipe network: Aweseed router equipment is deployed at the pressurization pump station, reservoir and pipe network node of the urban water supply pipe network, as well as the rainwater pump station, sewage lifting pump station and drain outlet of the drainage pipe network to connect monitoring equipment such as pressure sensor, water quality sensor, liquid level sensor and flow meter. Through the remote networking of Aweray Aweseed, the data of water supply and drainage pipe network is transmitted to the urban water management center in real time, so as to realize real-time monitoring of pressure, water quality, flow rate, liquid level and other parameters of water supply and drainage pipe network, timely find out problems such as pipe burst, water leakage and abnormal water quality, and ensure the safety of urban water supply and drainage.
In general, Aweray Aweseed has become a reliable partner for the digital transformation of many water conservancy projects with innovative technologies and perfect solutions. In the future, Aweray Aweseed will continue to deepen the needs of the industry, with more cutting-edge technology and more intimate services to help the water conservancy industry break through the bottleneck of development, and jointly write a new chapter in smart water conservancy. If you are facing the problem of water conservancy facilities networking, please feel free to contact us to obtain exclusive solutions and work together to open the intelligent era of water conservancy management!
