Access control system remote access, real-time data synchronization problems, Aweray Aweshell intranet penetration easily solved
In the daily operation of the smart park, the access control management system is responsible for ensuring the safety of personnel, standardizing the access process and improving the management efficiency. Because the access control system involves a large number of personnel information and access records and other sensitive personal information data, local deployment has become the best choice.
Picture alt
However, for large-scale parks with multiple entrances and exits or distributed in different areas, it is difficult for managers to monitor and manage the operating status of each access point in real time.
In the face of such problems, Aweray Aweshell bring solutions. With the help of this scheme, access control systems in various regions can be opened without public network IP, and centralized access to the headquarters system. At the same time, relying on the Aweshell perfect security protection mechanism of the Aweray, it not only ensures the security of data transmission, but also meets the needs of cross-regional and cross-departmental efficient collaborative management.
Picture alt
Aweray Aweshell not only achieve high-speed remote access, but also precise control of access rights to ensure secure remote connections!
Aweray Aweshell intranet penetration service not only uses BGP computer room clusters with redundant backup of multiple lines, but also fully covers mainstream operators at home and abroad (such as telecom, Unicom, mobile, etc.), and is distributed in multiple regions of East China, South China, North China and Southwest China. It intelligently selects the optimal line and effectively ensures high-speed access across regions and operators.
Picture alt
At the same time, for the personal sensitive information involved in the smart access control system, the Aweray Aweshell uses the RSA encryption algorithm and combines the AES algorithm for hybrid encryption to provide double security, and will not store communication data to ensure the safety of data transmission.
Picture alt
Aweray Aweshell also has multi-dimensional status monitoring, multi-channel alarm notification and fine-grained "access control" function, which can accurately set access permissions, such as specifying specific time, IP address, region, browser and operating system version to remotely access mapped devices or services.
For web systems, additional access password verification can also be set to further improve protection capabilities and fully meet the needs of security management.
Aweray Aweshell, simple 3 steps to achieve remote access
Step 1: Download the Aweshell client in Aweray official website, register the Aweray account, and install and log in the client on the intranet server.
Picture alt
Step 2: Enter the Aweshell cloud management platform → Click intranet penetration → Add mapping → Select the mapping type to start creating. Fill in the LAN IP and access port number of the smart access control system.
Picture alt
Step 3: Set according to the prompt, click Save, and a fixed remote access address will be automatically generated.
Picture alt
By entering the address in the browser, you can achieve remote access to the smart park access control management system. Managers can use the address of the access control system for real-time monitoring, rights management and other operations.
In summary, Aweray Aweshell provides remote data synchronization and remote access solutions for the smart park access control system by virtue of its powerful intranet penetration technology and secure and compliant data protection mechanism. It not only solves the pain points of multiple entrances and exits and multiple regions that are difficult to manage in a unified way, but also ensures the security of sensitive data during transmission. Through simple configuration, you can easily achieve cross-regional, cross-network efficient collaboration and precise control, help the park management wisdom upgrade, security code.
