Remote work has transformed the flexibility of how businesses and individuals operate; employees are no longer tethered to a single office location, and "digital nomads" have the freedom to travel while they work. However, this shift can present challenges for companies in terms of resource management.
How can businesses create a connected, digital work environment? How can employees access internal resources while working from home or visiting clients off-site? The workplace ecosystem relies on three key components: employees, devices, and business applications. AweRay helps enterprises build a connectivity architecture that integrates these elements, establishing a practical and effective remote work environment.
The Three Layers of a Connected Digital Workplace
How can employees, devices, and business applications be connected? Breaking down the underlying logic, these three key components correspond to the endpoint layer, the network layer, and the application layer—with each layer presenting its own unique connectivity challenges.
Endpoint Layer: Connecting Employees to Their Work Computers
This layer is all about individual productivity. Plenty of teams still rely on heavy office desktops, local design software, or massive files sitting on a work drive that simply can't be moved to the cloud. Remote desktop software lets staff log straight into their office rigs from home—giving them full desktop control while saving IT teams from driving on-site just to fix a minor glitch.
Network Layer: Connecting Devices Across Multiple Locations
Here, the challenge shifts from a single PC to scattered hardware spread across offices, warehouses, and factory floors. You might have security cameras at HQ and data loggers in a remote plant sitting on completely separate local networks that can't talk to each other. Virtual networking fixes this by linking those isolated sites over your existing internet connection, letting teams manage off-site equipment without ripping out or rebuilding physical cables.
Application Layer: Connecting Employees to Internal Business Systems
Most businesses still host core tools—like ERP systems, OA platforms, or NAS storage—on local office servers that block outside traffic by default. Port mapping (or port forwarding) opens a specific doorway to route external requests straight to those internal apps. Just don't leave that door unlocked: always pair port forwarding with strong passwords, encryption, and strict firewall rules, and never expose services that don't actually need outside access.
How to Build a Connected Digital Workplace
So, building upon these three levels, how can an enterprise connect its employees with its work materials?
How to Give Remote Staff Direct Access to Office PCs
Don't bother migrating heavy files or reinstalling licensed apps on personal laptops. Just drop a remote desktop tool like AweSun onto your office desktops so staff can log straight into their work rigs from home. With the "unattended access" feature, staff can connect to their computers at any time, even when away from the office, and retrieve urgent files using built-in file transfer capabilities. Furthermore, IT teams no longer need to travel to the office to resolve minor technical issues.
How to Link Hardware Across Separated Branch Networks
Cameras at headquarters, sensors in factories, and workstations at various branch offices often remain isolated from one another because they reside on separate local area networks (LANs). You don’t need to pay for expensive leased lines, rewire your infrastructure, or reconfigure routers to solve this. The secret lies in using a software-defined wide-area network (SD-WAN) or "virtual LAN" tool—like AweSeed—to connect these dispersed sites over the existing internet. This allows IT administrators to monitor and manage all devices remotely through a single, unified, and encrypted network.
How to Safely Access Internal Apps Without a Public IP
Running an in-house ERP, OA platform, or office NAS on a local server usually means paying extra for a static public IP just to let remote staff in. Port mapping tools like AweShell let you skip that hassle by tunneling only those exact apps to the outside while keeping the rest of your network dark. Just make sure you lock those tunnels down with strong logins and firewall rules so outsiders stay out.
How to Collaboratively Build a Digital Workplace
How do these three connecting layers work together to build a digital workplace? Are there any useful tools available? We’ve prepared a quick reference table to help you find out.
| Architecture Layer | Core Bottleneck | Target Connection | Recommended Tool | Business Outcome |
| Endpoint Layer | Employees cannot access their office computers remotely | Employees ↔ Office computers | AweSun | Remote productivity and IT support |
| Network Layer | Devices and local networks are separated by location | Devices ↔ Distributed networks | AweSeed | Cross-location device connectivity and management |
| Application Layer | Internal services are not reachable from outside the network | Remote users ↔ Internal applications | AweShell | Access to selected business systems and data |
Say you have a main headquarters, two branch offices, and a few folks working from home. Those remote staffers need remote desktop software just to control their office PCs, while your IT guy uses virtual networking to reach servers across the branches—and if someone needs an old-school ERP app sitting on a local machine, port mapping punches a clean route straight to it.
There is no single, all-encompassing tool; the best approach is to combine solutions based on your specific needs. You can use remote desktop for screen access, connect geographically dispersed devices via virtual networks, and employ port mapping to support particular applications—integrating these methods is the most practical way to build a modern work environment.
Where Should Businesses Start?
Don’t try to set up all three layers on day one. Fix whatever is slowing your team down right now, and add the rest only when you actually outgrow it:
- Start with remote screens: If folks just need to reach their office PCs from home, AweSun handles daily remote work and quick IT fixes without forcing you to migrate local files to the cloud.
- Link up scattered sites: Once you expand into multiple branches or off-site gear, one-to-one screen control gets messy fast—which is where AweSeed steps in to tie those separate devices and local networks together virtually.
- Open up internal apps: Later on, if staff also need direct access to an in-house ERP or office NAS, AweShell takes care of the port mapping so you only expose the exact apps they need.
There is no need to deploy multiple tools all at once; instead, it is recommended to build your organization’s remote work infrastructure step by step, following the process outlined above.
Can remote desktop software serve as a substitute for virtual network solutions?
Not in every scenario. If employees only need to control their office computers, remote desktop software like AweSun may suffice; however, if the requirement involves interconnectivity across multiple locations and various devices, a virtual network solution—such as AweSeed—would be more appropriate.
How can remote employees access an internal ERP system or NAS?
If an ERP system or NAS is deployed within a company’s internal network, external access can be enabled through port mapping or tunneling technologies. AweShell, for instance, allows enterprises to provide remote access to internal applications and services without requiring a public IP address.
What are the advantages for enterprises in building a digital workplace?
When implemented effectively, it can lead to improved operational efficiency and resilience, an enhanced employee experience, stronger security and compliance, a better customer experience, and cost optimization.
Is cloud migration required to build a connected digital workplace?
Not necessarily. Cloud services may not fully encompass the on-premises servers, specialized hardware, or office workstations that an enterprise requires.
A working remote setup takes way more than just buying a bunch of chat and video apps. Splitting screen control, device networking, and app access into separate jobs keeps your setup from turning into a tangled mess as you grow. Aweray simply gives you the individual pieces to plug in whatever you need next—without forcing a massive overhaul.
