How to remotely transmit power facility monitoring data? Aweseed brings cost-effective networking solutions
AweRay TeamAweRay Team
The frequent occurrence of extreme weather such as high temperature and heavy rain in summer is bringing unprecedented challenges to the power industry. In this context, the traditional offline operation and maintenance mode is becoming more and more inadequate. Bad weather not only hinders the operation and maintenance personnel from arriving at the scene in the first time, but also makes it more difficult to ensure the continuous and stable operation of the power system. In contrast, remote operation and maintenance has become the mainstream solution to deal with extreme weather and ensure reliable power supply by virtue of its advantages of breaking through time and space constraints.
Picture alt
As a leading brand in the field of off-site networking,Aweseed provides reliable support for the power industry with SD-WAN-based innovative technical solutions: through stable cross-regional network connection, it ensures efficient transmission of operation and maintenance instructions in harsh environments such as high temperature and rainstorm; Multiple safety protection systems build a strong power data transmission barrier to meet the strict safety standards of the industry; Lightweight deployment and flexible expansion capabilities to quickly adapt to the operation and maintenance requirements of different power scenarios, let the summer power system stable operation more secure.
Picture alt
In view of the pain points faced by the power industry in extreme weather and complex operation and maintenance scenarios,Aweseed can solve the following problems through remote networking solutions:
●Aweseed to ensure core network link redundancy: high-temperature equipment downtime to avoid remote monitoring, operation and maintenance interruption
When the core switch is overheated and offline due to high temperature, it is Aweray to Aweseed remote networking hardware to support solutions such as multi-channel network redundancy backup and dual-computer hot standby. Take the R300 series industrial router with the largest market share of online e-commerce platform in China in 2024 as an example, it supports multi-link backup such as wired, 4G/5G, and can realize dual-machine hot standby to ensure real-time online.
Picture alt
When the switch and gateway in the power facility computer room are offline, theAweseed scheme can automatically switch to the backup link in real time. At the same time, for 4G/5G network, in addition to dual-card backup, it also supports theAweseed of three-access cards, which can switch between telecom, Unicom and mobile in real time and automatically access the operator with the best signal.
Picture alt
Through the Aweray of Aweseed and perfect network mutual backup mechanism, not only can the continuous transmission of power monitoring data be ensured, but also the operation and maintenance personnel can remotely access the background of the equipment through the private network in case of network failure, quickly locate the causes of switch overheating (such as hardware failure and excessive load), and avoid the stagnation of troubleshooting due to the downtime of a single equipment.
Aweray Aweseed self-developed global intelligent link and weak network optimization technology: power equipment monitoring data is transmitted smoothly and in real time across regions.
In the peak period of power consumption, the traditional power communication network is often congested due to the surge of data traffic, the data of SCADA system is prone to serious delay, the feedback of load control instructions is slow, which can easily lead to the failure of power grid scheduling and chain trip. The global intelligent link of theAweseed can be accurately solved, and the optimal link can be intelligently selected to ensure the priority transmission of production data, and the key instructions can enjoy the high-quality channel to alleviate congestion.
Picture alt
A large amount of high-definition video, image and audio data will be generated in the process of power inspection, which puts forward high requirements on the bandwidth, delay and stability of the network. For video monitoring data of power facilities, Aweseed can automatically identify abnormal network conditions such as weak network, packet loss and jitter through self-developed weak network optimization technology on the basis of global intelligent links, and dynamically adjust video stream priority, compression and fault tolerance strategies to ensure that important monitoring images are still smooth, continuously flowing and free of screen display even in complex environments such as network congestion and high packet loss.
Picture alt
● Full-link data encryption, fine authority control,Aweseed to protect power data security and compliance
In the power industry, data compliance is the core bottom line to ensure the safe and stable operation of the power system. Its requirements run through the whole process of data collection, transmission, storage and access: it not only needs to meet the protection requirements of the "Network Security Law" and "Data Security Law" for key information infrastructure, but also needs to meet the strict regulations of "data transmission encryption, controllable access rights and traceable operation" of the power monitoring system in other security standards, especially for sensitive information such as inspection data and monitoring instructions, it is necessary to prevent leakage, tampering or unauthorized access.
The security system of theAweseed is highly compatible with the data compliance requirements of the power industry, and it has passed the three-level certification of information system security level protection. In addition, theAweseed starts from the user access layer and builds the first line of defense through multi-factor identity authentication to ensure that every access can be traced back to a specific authorized person.
At the same time, the Aweseed has fine management of authority and strictly follows the principle of "minimum necessity". It can delimit the access scope according to posts, responsibilities and even operation scenarios, prevent irrelevant personnel from touching the core monitoring data and equipment control authority, and perfectly adapt to the safety logic of "hierarchical control" of power facilities. In the data transmission link, the Aweseed uses RSA/AES hybrid asymmetric encryption technology combined with the national secret algorithm to realize the full encryption of inspection data and scheduling instructions from the terminal to the cloud, effectively preventing the risk of eavesdropping and tampering in the transmission link.
For scenarios with a higher level of security, the privatization deployment mode can limit the data storage and processing links to the enterprise's own servers, meet the compliance requirements of the power industry that "data does not go out of the domain", and ensure the efficient operation of the power monitoring system under the premise of safety and compliance.
The application ofAweseed in the power industry has brought a new solution for summer power operation and maintenance. Aweray solution successfully breaks through the dilemma of traditional operation and maintenance mode in terms of safety, efficiency and data transmission, and ensures the stability, reliability and security of remote control. In the context of frequent extreme environments,Aweseed and Aweray Aweshell provide a solid technical support for the stable operation of the power industry.
