"Small and Strong" Network-Free Remote Control, Awesun Q1 Released
AweRay TeamAweRay Team
Aweray Awesun Intelligent Network-Free Remote Control Equipment Family Added New Member-Awesun Q1!
As the smallest member of the Awesun intelligent remote control equipment without network in past dynasties, Awesun Q1 sparrow is still powerful although it is small and has all five internal organs!
Best of all, it supports plug and play as well as family members! Without tedious installation, BIOS level remote control can be realized for any equipment and system. It can be easily handled!
At present, the small and powerful Q1 has been put on the shelves for pre-purchase, and the price limit is 289 yuan.
How to realize "remote control without network"?
Remote control must use the network, but the controlled device itself does not necessarily need to be directly connected to the network.
Awesun Q1 still adopts the same non-network remote control principle as the series of hardware products. The network required for remote control is connected to Q1 equipment instead of the controlled equipment. During connection, Q1 implements remote control through analog video and keyboard and mouse signals, which is isolated from the network environment of the controlled equipment itself. While meeting the requirements of network security, it realizes "non-network remote control" and is very suitable for equipment operation and maintenance scenarios such as intranet servers.
Ultra-small size, simple and exquisite
The Awesun Q1 adopts a minimalist design. The aluminum alloy shell feels warm and moist without losing the aesthetic feeling of science and technology. The body weight is only 63 grams. The ultra-small size can be mastered by one hand, greatly reducing the space occupation and improving portability.
No need to drive, convenient to use
Awesun Q1 controlled end does not need to install any software and drivers, is compatible with Windows, macOS, Linux, Android, iOS and other systems, provides BIOS-level full-process remote control, and can also remotely operate and troubleshoot the blue screen of system crash.
At the same time, Awesun Q1 supports a variety of device types, including but not limited to desktop, laptop, tablet, mobile phone, server, NVR, etc.
In terms of connection and use, Q1 uses Bluetooth binding, supports Bluetooth 5.0, and can complete the connection with common wires. The process of using the distribution network for the first time is convenient and quick.
In addition, even if the controlled device itself does not have a display, Awesun Q1 can smoothly control it remotely, which is very suitable for scenarios such as enterprise IT computer room operation and maintenance.
The combination of the above advantages can help enterprises effectively broaden the technical boundaries of remote control business, making it possible for many scenarios that could not be remote.
At the same time, Awesun Q1 can also link more types of equipment to realize other advanced play methods: although Q1 itself does not support HDMI loop-out, it can be matched with HDMI distributor (screen splitter) to realize remote control of video signal loop-out, or it can be matched with Awesun smart socket to build a closed-loop remote maintenance system of "remote startup-control.
Of course, if we need video loop-out, or WiFi, 4G network access and other capabilities, we can also directly choose to Aweray other models in the Awesun intelligent remote control hardware series, such as the enterprise-class basic explosion Awesun A2.
If it is a more high-end advanced vertical scene, you can also choose industrial hardware Awesun Q2Pro; Or support 5G network, can be initiated by one party to accept remote assistance Awesun Q5Pro and so on.
The release of Awesun Q1 further enriches the product sequence of Awesun control series intelligent hardware and provides us with more choices.
