Help build anti-fraud platform, Aweray Awesun privatization deployment scenario case analysis.
The intranet systems of enterprises and government agencies are like data islands. Strict management of gateways, even direct physical isolation, can meet the security needs of enterprises to the greatest extent.
But on the other hand, such "isolated island" also creates no low difficulties and thresholds for the daily operation and maintenance of the intranet, and even the construction of some monitoring, remote training and other business systems. How to find the "balance point" among them and implement the remote connection and access of intranet equipment under the premise of security has become a topic that IT departments must face.
In the face of this topic, Aweray Awesun provides a set of mature solutions, around the "privatization deployment" and professional "intelligent remote control hardware without network" equipment, which can realize safe and controllable remote access to the intranet, and has been adopted by many enterprises and government units. Here we will introduce one of the scene cases.
Case background and demand pain points:
A local public security bureau anti-fraud center set up a set of intranet business system, the system carries business training and other core business, there is a wide range of remote access needs, but for compliance reasons need to log in through the designated bastion machine equipment, while the login process requires face recognition authentication.
At the same time, another system of the unit also needs the support of remote control technology. The system originally needs VPN environment connection, but after VPN is turned on, there is a security policy conflict with other applications, which affects normal use. Therefore, a remote control scheme that requires security compliance and does not install any software and drivers at the controlled end.
To sum up, the core requirements of this case are divided into two scenarios:
● Support many-to-one single-point remote control for remote face recognition
● Secure remote control without VPN and software driver installed at the controlled end
Combined with the above needs, Aweray Awesun provides it with a composite security remote control solution based on the privatization deployment to Japan and the intelligent remote control hardware Awesun Q2 Pro.
Plan Deployment and Implementation
The program uses a Awesun of privatization deployment services, a total of more than 10 concurrent, to achieve remote access to the intranet bastion machine, and through the bastion machine login business system. The human identification requirement in the login process is realized by Awesun the remote camera function. In the private deployment service, the Awesun remote camera supports the IP redirection function, which well meets the needs of this case.
In addition, for another core scenario, the unit chose to introduce Awesun intelligent remote control hardware Q2 Pro. Through bios-level remote control, remote control can be realized without installing any software and drivers at the controlled end, thus solving the problem of conflict between the security policies of the original VPN and business software.
Awesun Program Core Benefits
In this case, the Aweray Awesun scheme mainly shows the following core advantages.
● Private deployment to meet compliance needs
Aweray Awesun privatization and deployment of mainstream hardware servers, support single cluster, multi-cluster, cross-data center deployment, support pure intranet deployment, support cross-multi-security domain network deployment, and can be accessed and used in different network domains. At the same time, the infrastructure is highly integrated and can meet the needs of enterprise units to independently master core data.
● Remote camera to achieve human identification mapping
The remote camera function supports IP redirection in private deployment mode, which solves the pain point of face recognition in remote process.
The function is equipped with perfect, high custom properties
At the functional level, privatization deployment service is an advanced scheme for Aweray to Awesun enterprise-level SaaS service: its basic remote control function experience is consistent with SaaS scheme, and at the same time, some more vertical management function Awesun teams will configure privatization deployment service first, which can meet many advanced requirements of enterprises and has higher customization than SaaS service.
● Lightweight advantages, lower deployment costs
Awesun privatization deployment services In the same type of enterprise privatization plan, the deployment of "lightweight" advantage is very obvious, the specific characteristics can be summarized as "containerization", "interface", "personalization".
Containerization: supports containerized deployment. It can be deployed in the existing K8s system of the user or run independently. Containerized deployment has high compatibility, easy management, and fast deployment.
Interface: support for third-party account access, support for docking third-party SMS, email, support for different brands, different models of IT assets, unified control through the platform.
Personalization: Support customization of the entire platform interface style, support for on-demand configuration of functions, and customization of access methods.
● Professional remote control hardware adapts to special remote control requirements
When solving the problem of conflict between VPN and business software security policies, the hardware scheme Aweray Awesun has well met the needs of the unit. The Awesun Q2 Pro included in it is a star product, which can solve the management problems of "no network connection and intranet isolation" in many special business scenarios.
At the same time, the strategy of pure physical connection network isolation can also fully meet the core security requirements of enterprise intranet operation and maintenance. In addition, the Awesun Q2Pro adopts an industrial-grade design that further integrates 4G modules and high-definition output capabilities, enabling it to flexibly adapt to more complex network environments and high-demand application scenarios.
Summary and evaluation:
In this case, the professional remote control scheme provided by the Aweray Awesun well meets the customer's complex remote control needs and is fully put into business use. At the same time, in view of the good performance in this case, the unit and the Aweray Awesun are still brewing More in-depth cooperation.
