Enterprise security remote control system how to build?
AweRay TeamAweRay Team
Nowadays, the enabling effect of remote control on business is obvious. Whether it is collaborative office within an enterprise, remote operation and maintenance management of internal IT equipment and front-line business equipment, or remote technical support to customers, remote control technology has become one of the network infrastructures of enterprises.
On the other hand, due to the characteristics of remote control itself, enterprises pay special attention to security when building remote control system. How to build a safe and professional enterprise-level remote control scheme has become one of the important topics. In this topic, how to build a remote control "authorization" system is an important part.
Here, let's take the enterprise-level remote control scheme of the national-level remote control brand "Aweray Awesun" as an example to see how the enterprise builds a remote control authorization system and what specific functions the Aweray Awesun carries to help the enterprise realize its safe remote control strategy.
Enterprise Remote Control has two authorization dimensions:
For the authorization of remote control, there are two main directions.
The first is the authorization of remote control qualifications for internal and external personnel, who can remotely control, what equipment can remotely control, at what time period can remotely control, and what equipment is used to initiate remote control. These can all be authorized objects to help enterprises establish an authorization system.
Then there is the authority management for the behavior in the process of remote control, that is, what positions of employees have the remote control authority corresponding to their responsibilities, so as to prevent potential safety hazards caused by ultra vires operation. Around these two dimensions, Aweray Awesun is equipped with a series of security functions:
● Equipment authorization management
Authorize the designated equipment to the corresponding members for remote control or management. The equipment can be authorized to internal personnel of the enterprise or external personnel (suppliers, partners, etc.) according to business requirements. This authorization can be withdrawn at any time. The IT department of the enterprise can design the overall authorization management framework based on this function.
● Restrict external personnel from remote control of internal equipment of the enterprise
If you do not want external personnel to remotely control the equipment in the enterprise, you can adjust the settings in [Remote Control Settings]-[Global Settings] to form a "black and white list of equipment" so that it cannot be remotely controlled by external personnel.
● Black and white list settings based on other conditions
We can also set the black and white list of remote control accounts based on other conditions, such as whether member accounts can log in to the main control terminal or management platform according to MAC address, IP address, time period, etc., to promote the landing of security policies in a more refined manner.
● Role permissions
For employees in different positions or external suppliers, we can use the "role permission" function to realize the fine authorization of remote control behavior and customize specific remote control permissions for different roles.
During the setting process, the Awesun management platform will also give necessary prompts. For example, when canceling [Cut File], it will suggest canceling [Send File] and [Receive File] at the same time to avoid logical loopholes.
● The safety setting of the controlled end
When we customize the remote control controlled end, we can also set and fix relevant security options to avoid accidental changes to the controlled end's verification code, certificate verification, privacy settings, etc. and become security exposures.
Beyond Business Security: Aweray Awesun Technical Security and Authoritative Certification
The security of remote control is largely based on a mature management authorization system. With the support of the above functions, enterprises can build a reasonable security strategy and form a security barrier at the business level.
In addition to the business level, the technical level and authoritative certification, Aweray Awesun is also commendable.
Awesun uses two-way RSA AES encryption transmission, but also supports the state secret SM2 SM4 two-way encryption transmission. At the same time, the Aweray Awesun also segregated the business of the enterprise version and the personal version, and the two do not interfere with each other. In terms of authentication, the Aweray Awesun ensure that only the accused client can issue the admission authorization for the remote session.
In terms of authoritative certification, the Aweray Awesun passed the third level certification of national information system security level protection (such as three), and obtained the international safety management system standard ISO27001 certification and ISO9001 quality management system certification. Aweray Awesun also jointly with the Shanghai Software Industry Association released the group standard "Technical Requirements for Remote Control Software", which is the first authoritative team standard in the industry.
In addition, the Aweray Awesun remote control scheme has also received authoritative recognition in terms of technical security: software products such as the Awesun enterprise version, the privatized deployment version and the SDK embedded version have participated in and passed the security penetration test conducted by the Shanghai Computer Software Technology Development Center, and have been rated as the "low-risk system" with the highest security level. It is a scheme in the remote control industry that has exclusively passed the security test by the national authoritative testing organization.
With the blessing of the above content, the security of Aweray Awesun enterprise remote control scheme is worthy of enterprise trust, and therefore has withstood the test of the market.
As a national-level remote control brand, Aweray Awesun has been deeply engaged in the field of remote connection for 19 years. China has more than 0.1 billion registered users, more than 1.2 million enterprise customers and more than 2 billion access devices. Large enterprises including Huawei, Vanke and Skyworth have recognized and used Awesun remote control services, forming a large number of benchmark cases in the industry.
