How to Access Your Work Computer from Home: Two Simple and Secure Methods
17660
Here tells you how to access a work computer from home via Windows 10 PC and you can complete work tasks at home.
Working remotely has become a normal part of modern life. Whether you need to access work files, use office-only software, or manage tasks outside business hours, being able to access your work computer from home is essential. This article introduces two reliable ways to access your work computer from your home computer: using Windows’ built-in Remote Desktop feature and using AweSun, a more flexible
1. Access the office computer from Home Windows 10 with RDC
Windows includes a built-in Remote Desktop feature that allows users to connect to and control another Windows computer remotely. This method is suitable for users who are comfortable adjusting system settings and network configu
Requiremen
The work computer must be running Windows 10 Pro, Enterpr
Remot
Both comput
Steps
First, on your work computer, open Settings,System, and select Remote Desk. Enable Remote Desktop and ensure Next, if you are connecting over the internet rather than a local network, you may need to configure port forwarding on the office router and allow Remote Desktop through the firewall.
图片alt
On your home computer, open the Remote Desktop Connection application built into Windows. Enter the work computer’s name or IP address and log in using your work account credentials. Once connected, you will be able to view and control your work computer as if you were sitting in front of it.
图片alt
While this method is effective, it can be difficult for users unfamiliar with networking, and improper configuration may pose security risks.
2. Using AweSun to Access Your Work Computer from Home
For users who want a simpler and more secure solution, AweSun provides an easier way to remotely access a work computer without complex setup.
Why Choose AweSun
AweSun is designed for ease of use and works across different networks without requiring port forwarding or advanced configuration. It offers encrypted connections, stable performance, and supports multiple access scenarios.
Steps
First, install AweSun on both your work computer and your home computer. Create an AweSun account and sign in on both devices.
Next, ensure the work computer is online and that remote access is enabled in AweSun. The device will automatically appear in your device list once logged in.
From your home computer, simply select your work computer from the list and connect. You can then control your work desktop, access files, and run applications remotely.
Additionally, AweSun allows you to install the app on your phone as well. By installing AweSun on both your home and work computers and signing in to the same account, you can also control your work computer directly from your phone whenever needed.
Which Method Should You Use?
Windows Remote Desktop is a built-in option that works well for users who are comfortable with system configuration and network security. However, it requires specific Windows editions and may involve additional setup steps.
AweSun is a more accessible option for most users. It is easier to set up, works across networks without manual configuration, and allows access from multiple devices, including phones. If you want a fast and straightforward way to access your work computer from home or on the go, AweSun is the recommended choice.
Accessing your work computer from home can significantly improve productivity and flexibility. While Windows’ built-in Remote Desktop feature offers a native solution, it may not be ideal for all users due to its setup complexity. AweSun provides a simpler, secure, and more versatile alternative, making it easy to control your work computer from your home computer or even from your phone whenever you need it.
