2025-09-05
Aweshell intranet penetration: to help smart agriculture autumn harvest efficient remote operation and maintenance.
Autumn is the golden season of agricultural production, and the smooth progress of autumn harvest is directly related to the harvest of the whole year. All kinds of Smart Device in the field, such as water and fertilizer integrated irrigation equipment, soil moisture monitoring stations, large harvesters, plant protection drones, greenhouse environmental control systems, and so on, need to operate at high intensity in a short time to achieve accurate operation and efficient management.
Picture alt
With the rapid development of smart agriculture, a large number of IoT devices have been widely deployed in the field. These devices are usually connected to the Internet through 4G/5G networks, with scattered distribution and complex environment, and most of them lack fixed public network IP addresses. The traditional remote access method is difficult to deploy and costly, which seriously affects the real-time scheduling of agricultural production and the efficiency of equipment operation and maintenance.
Aweshell intranet penetration scheme to create a new base for agricultural remote management
In the face of the above difficulties, Aweshell intranet penetration provides a safe, stable and efficient remote connection scheme for agricultural Internet of Things equipment, which greatly improves the equipment management efficiency and system reliability during the autumn harvest.
Picture alt
No need for public IP, rapid deployment, lower the threshold of agricultural digitization
Field equipment usually relies on 4G/5G network access and does not have fixed public network IP. Traditional remote access relies on dedicated lines or complex configurations, which is costly and difficult to implement.
Aweshell intranet penetration technology, no public network IP, no need to change the existing network structure, just install the Aweshell client on the irrigation controller, weather station, greenhouse control host and other equipment, you can quickly generate a fixed domain name.
Technical personnel can log in to the equipment management interface remotely by inputting the domain name through the browser, realizing remote access within a few minutes, and greatly reducing the difficulty of deployment and maintenance of the agricultural Internet of Things system.
High reliable transmission to ensure continuous operation of agricultural machinery and real-time data return
During the autumn harvest, plant protection unmanned aerial vehicles need to return high-definition video in real time, and intelligent agricultural machinery needs to continuously report the operation status. Any network interruption may affect the operation safety and efficiency.
Aweshell relies on BGP multi-line data center clusters to realize intelligent routing across operators, significantly reducing latency and packet loss. Even if the network is switched due to the movement of the equipment, the Aweshell can continue to transmit through the implementation of the nearby node, ensuring that the video stream and data stream are not interrupted, and providing stable and reliable network support for agricultural command and dispatch.
Picture alt
Refined access control to achieve permission classification and operational security
In agricultural scenarios, there is often a need for multi-person collaboration. For example, the headquarters needs to access environmental data of greenhouses in various places, and branch technicians only need to operate and maintain local irrigation equipment.
Aweshell supports setting access policies in multiple dimensions, such as time, IP address, region, and operating system. For example, you can set to allow access to the field control system only during working hours, or add the headquarters IP to the white list to prevent unauthorized access. This kind of refined authority management effectively avoids the risk of misoperation and unauthorized access while realizing collaborative work.
Picture alt
Multiple security protection, building a" security fortress "of agricultural Internet of Things
Once the core production systems such as irrigation control and greenhouse regulation are invaded, crop production will be directly affected. Aweshell supports secondary password verification in addition to basic identity authentication. Even if the access address is exposed, unauthorized users cannot log in.
The system also has a blasting protection function, automatically identifies and intercepts malicious login attempts, effectively resists network attacks, and provides bank-level security for the agricultural remote management system.
Real-time threat detection, blocking the spread of risk at the device layer
There are various types of agricultural field equipment, and some equipment may have security vulnerabilities due to old firmware. The built-in threat detection module of the Aweshell client can identify abnormal behaviors such as viruses and Trojan horses in real time. Once a risk is found, external access is immediately interrupted and an alert is reported. For example, when a plant protection drone control terminal is infected with malware, the Aweshell can isolate the device for the first time to prevent the threat from spreading to the entire agricultural network.
Picture alt
Status real-time monitoring and multi-channel alarm, to achieve unattended operation and maintenance
Agricultural equipment is widely distributed, traditional manual inspection is inefficient, and a certain point is dropped, which may be unnoticed for a long time. The Aweshell provides multi-dimensional monitoring and real-time alarm functions. Once a device connection is interrupted or traffic is abnormal, the system can notify the administrator in the first time through multiple channels such as App, email, DingTalk, and enterprise WeChat. Although agricultural managers are far away from the command center, they can still fully grasp the online status of the equipment, respond to abnormalities in time, and maximize the continuity and stability of autumn harvest operations.
Picture alt
In general, the Aweshell intranet penetration scheme provides efficient remote device access and management capabilities for smart agriculture with its core advantages such as no public network IP, easy deployment, stable connection, and safety and controllability. Whether it is field environmental information collection, remote operation and maintenance of agricultural machinery, drone patrolling operations, or cross-regional greenhouse intelligent control, Aweshell can build a smooth, reliable and safe digital channel, significantly improve the intelligent level of agricultural production And operational efficiency, escort the autumn harvest.
